T TurboBusa huh?? Joined Jun 16, 2004 Mar 21, 2007 #1 2 questions what type of power steering fluid do we use? where is the closest vendor for methanol in the yorktown virginia? thanks
Q QUIP'6' Brian Roman Joined Nov 26, 2003 Mar 21, 2007 #2 TurboBusa said: 2 questions what type of power steering fluid do we use? where is the closest vendor for methanol in the yorktown virginia? thanks Click to expand... dextron 111. as for alky check methanol sources in sticky
T TurboBusa huh?? Joined Jun 16, 2004 Mar 21, 2007 #3 thanks, i knew it was dex 3. i really needed to make sure cause my friend uses this clear stuff. i had to finally change the original pump. as for the methanol i'll have to call around. i miss my sources on the west coast:frown:
