My antenna is stuck in the up position. I think I read that you need to lower it to be able to remove it. My motor runs when I connect the lead, so I thought I might be able to push it down with the motor running, but no luck, it won't budge. Any thoughts?
Do I need to lower it to get it out? Will I need to cut it off if it won't go down? Thanks.
