Ported stock intake, 2 welded cam sensors, fuel rail w/-10AN, 2 turbo brackets & more
SPOT MY 6
Stock crawlin National...
Another parts list for sale. Everything here is in excellent-mint condition, I dont sell any junk or marginal parts. First one to pay for a part gets it, I am not holding parts for anyone anymore, too many people back out of deals. All prices are plus shipping and paypal fees. If you want multiple parts shoot me a PM with an offer and I'll make deals, just be reasonable. :D
- 3 cam sensors, 2 of which have been welded by Anderson Performance to prevent sensor from coming out of adjustment (mod alone was $75/ea). 2 welded sensors: $150/ea. 1 un-modified sensor: $75
http://home.comcast.net/~gnat86/parts/cam_sensors1.jpg
http://home.comcast.net/~gnat86/parts/cam_sensors2.jpg
- 3 cam sensor caps. 2 are cracked. 1 is mint. I used the cracked one with the black electrical tape on my TSM motor with no issues. The cracks don't effect the sensor at all. $50 for all 3
http://home.comcast.net/~gnat86/parts/caps1.jpg
- ported stock intake to FelPro1200's. EGR is welded shut removed. There is a tap in the back of the intake for your IAT sensor (for aftermarket ECU's, FAST, BS3, etc). You can plug it if you dont needed it. There is also an air fitting in the valley to connect a crankcase pressure gauge. I never hooked up my gauge and it is currently capped. None of the SENSORS in the pictures are included, but all fittings are including the billet water neck with 160 stat. Came off my 9 second stock block gn. $325
http://home.comcast.net/~gnat86/parts/intake1.jpg
http://home.comcast.net/~gnat86/parts/intake2.jpg
http://home.comcast.net/~gnat86/parts/intake3.jpg
http://home.comcast.net/~gnat86/parts/intake4.jpg
http://home.comcast.net/~gnat86/parts/intake5.jpg
http://home.comcast.net/~gnat86/parts/intake6.jpg
http://home.comcast.net/~gnat86/parts/intake7.jpg
http://home.comcast.net/~gnat86/parts/intake8.jpg
- 1 stock fuel rail with a -10AN fitting welded on the feed side. $65
http://home.comcast.net/~gnat86/parts/rail1.jpg
http://home.comcast.net/~gnat86/parts/rail2.jpg
- 2 turbo brackets. 1 has enlarged holes for larger turbos and one nut ground down where the shield bolts to (I needed to do this just about all aftermarket turbos I ran). Still very nice shape $50. The other bracket is completely un-modified, show quality mint. $75
http://home.comcast.net/~gnat86/parts/turbo_brkt1.jpg
http://home.comcast.net/~gnat86/parts/turbo_brkt2.jpg
- ARP rod bolts for stock rods $45
http://home.comcast.net/~gnat86/parts/arp1.jpg
- 12" l/u 3000 stall converter. Not sure what brand it is. Nothing wrong with it, just switched to a non-lockup unit since the combo changed. Here are the numbers stamped on it:
4
2C523K1
3
K3 2R 065
C24HD
$200
http://home.comcast.net/~gnat86/12lu_600.jpg
http://home.comcast.net/~gnat86/12lu2_600.jpg
- Stock balancer with pulley and bolts $95
http://home.comcast.net/~gnat86/parts/bal1.jpg
http://home.comcast.net/~gnat86/parts/bal2.jpg
- One ProGram billet center main cap. Machined only ONCE $50
http://home.comcast.net/~gnat86/parts/cap1.jpg
http://home.comcast.net/~gnat86/parts/cap2.jpg
- Intake heater lines with valve (very nice shape) $95
http://home.comcast.net/~gnat86/parts/heat1.jpg
http://home.comcast.net/~gnat86/parts/heat2.jpg
- Comp 885 "R" series lifters. Very little use (15 passes). $325
http://home.comcast.net/~gnat86/parts/lifters3.jpg
- Manley 5/16" 8.500 pushrod set $60
http://home.comcast.net/~gnat86/parts/pr1.jpg
Ported intake SOLD
ARP rod bolts SOLD
Fuel rail SOLD
Everything else still available!
Ported intake SOLD
ARP rod bolts SOLD
Fuel rail SOLD
Everything else still available, I'm open to offers, just PM them to me!
Ported intake SOLD
ARP rod bolts SOLD
Fuel rail SOLD
Pushrods SOLD
Lifters SOLD
Here is the current list as of today along with new prices:
- Complete BigStuff3 system with WB02 and Buick Plug-n-Play harness $995!!!!!!!!!!! (see this thread: http://www.turbobuick.com/forums/parts-sale/301079-bs3-wb02-buick-plug-n-play-harness.html)
- 95lb Delphi low-z injectors, less than one racing season (500 miles, 15 passes). Bought from Racetronix (flowmatched, etc). Like new $300 (http://www.racetronix.biz/itemdesc.asp?ic=17113744&eq=&Tp=)
- 3 cam sensors, 2 of which have been welded by Anderson Performance to prevent sensor from coming out of adjustment (mod alone was $75/ea). 2 welded sensors: $125/ea. 1 un-modified sensor: $60
- 3 cam sensor caps. 2 are cracked. 1 is mint. I used the cracked one with the black electrical tape on my TSM motor with no issues. The cracks don't effect the sensor at all. $40 for all 3
- 2 turbo brackets. 1 has enlarged holes for larger turbos and one nut ground down where the shield bolts to (I needed to do this just about all aftermarket turbos I ran). Still very nice shape $40. The other bracket is completely un-modified, show quality mint. $70
4
2C523K1
3
K3 2R 065
C24HD
$150
- Stock balancer with pulley and bolts $75
- One ProGram billet center main cap. Machined only ONCE $35
- Intake heater lines with valve (very nice shape) $75
Feel free to PM me offers on any of this stuff.
Ported intake SOLD
ARP rod bolts SOLD
Fuel rail SOLD
Pushrods SOLD
Lifters SOLD
BS3 system SOLD
95lb injectors SOLD
Everything else in the post right above is still available. I'm open to offers so shoot me a PM if you are interested in anything.
