Junior Samples
Walk Away
- Aug 3, 2007
good to hear, I musta missed the second post from you stating check light was on.
Well next time you get weird hesitation, flat spot, bog, running rough er whatever, always start car check sm for low maf number and tap on maf first and note any changes if any. also the tps trick. sometimes it will get a flat spot and you can see it on SM.
go and make sure all grounds are tight,...im sure you have went and looked for more missing bolts already:biggrin:just shaking them loose from all them street fights
