I’ve got a problem with my Power Master brakes. The car sat idle for over a year. I went to move it and found that the reservoir was almost empty. The brake pedal goes to the floor with no back pressure and when the pedal is pressed the pump runs and the brake warning light comes on. There is no fluid on the ground. The car has the replacement brake switch. Adding fluid didn’t make any difference.
My guess is somehow the accumulator has failed and the fluid went into the accumulator.
Any suggestions? Vacuum conversion is not an option since the car is a GNX.
