strikeeagle
- Jun 6, 2001
First of all, this isn't a dis this and dis that thread, so don't even go there.
I read where the TA block is projected to be in the low $3000 range.
What niche does this block fill? I mean, what is the advantage of the TA block relative to a stage block? Isn't a stage block cheaper? And don't both blocks require forged cranks, aftermarket rods, forged pistons, etc. That is, you wouldn't put the stock stuff back in your $3000+ TA block, even if you could, would you? I mean, you wouldn't put a cast crank in a TA block, would you?
So educate me. What does the TA block do for you? I know it saves a few pounds, and it won't "dry up" like the stage blocks are, but won't it cost just as much to build one of these as it does a stage block?
That is, it isn't meant to fall in price-wise between a 109 motor and a stage motor, is it?
Help me understand here, and no bitching, please...
