sparky0798
- Jan 23, 2012
I am looking for the little plastic clip that holds the threaded rod in the ac/heat box blend door. I'm not sure what its called. It's not the one you see from inside the glove box but if you remove the top of the heat box it's in the same compartment as the heater core. Thanks
