Here is today's logfile: http://www.grimster.org/LogFile.dat
I hooked up the laptop and did some test logging today, also hooked up a fuel pressure gauge it reads 43 with the hose off, and taping the gauge to the windshield and running up and down the road it looks like it goes up 1:1 with boost,it was reading a pretty flat 50 psi at 10psi boost, it reads about 38 with the hose on and just idling.
Mods: 60# injectors ordered with a TT 91 octane chip, 3" Impala MAF + Translator, 3 bar map sensor, TE44, as you can see in the logfile it tops out around 15psi and is using the wastegate with an adjustable arm, hotwire kit, new Walbro (forget if it's 307 or 340), supposedly has an upgraded stall and shift kit, and 3" exhaust.
The FPR is not upgraded yet, is this pretty much a must upgrade too?
Any other changes I should do before looking at Alky? I hear people talking about O2's a lot, how do mine look?
As always all help and advice is mucho appreciated!
