anyone have pics of a msd crank trigger on a stage 2 with the stage 2 timing cover. im having problems finding a spot to mount it. i have a 5 stage dry sump on one side and a alternator on the other. ????
My motor is being put together with a stage 2 cover and an external oil pump on the passenger side. I'll be making a bracket to mount my sensor on the drivers side of the motor using the holes for the stock style crank trigger mount. There are a couple 1/4-20 holes there and a couple 10-32. Since you control timing with the efi system, there really is no need for adjustability of the crank trigger sensor once you get the crank reference angle where you want it.
