Daniel Jost
Squirtin six
- Oct 11, 2003
Here is the list and the pictures will be following. All prices plus shipping
-Comp Cams 208/214 cam with lifters (labeled when removed), double roller timing chain with roller cam button, heavy duty valve springs, and chromoly stock length push rods it all has about 10K miles on it.(pictured as just cam, springs, and pushrods). $150
- New Reed Cam Int 210/Exh 205 on 110 lobe center. I have the sheet that came with this cam. It was installed in a new short block I bought and never ran. It will come with a new double roller timing chain and roller cam button that have also only been installed. This cam does NOT have lifters $90
- Heat Treated Sun Gear shell and Hardened Stator Support, both brand new never used. $60
- Moroso valve cover breather pair $20
- RJC Rocker shaft rocker retainer replacement kit. $20
- Cam shaft sensor, could use a rebuild but worked when removed $65
- Double roller timing chain assembly $30
- NX alcohol injection solenoids, brand new never used didn't like how they looked Part# 15055 $75 for the pair
- Chrome Alternator fan, installed briefly and wasn't a fan of all the chrome with the billet pulleys. $15
Thanks, Dan
Thanks, Dan
