PCV Relocation? Fel-Pro 1200 Intake Gasket
2buicks
It's NEVER "Done".
Hi,
I was wondering if anyone was using the Fel-Pro 1200 intake gasket (w/o valley pan) and ran into PCV issues? (ie. sucking oil as the PCV sites right above where the oil drains back from the valve cover area) I have a set of cylinder heads that were ported and matched to the Fel-Pro 1200's, and was sittin' here thinkin' about it....I could relocate the PCV..maybe to the passenger side valve cover...:frown:
Greg
I have what you need.
$35 shipped brand new aluminum valley pan.
Edit - I have one of these on my GN and have no pcv issues.
Cool!
I assume the "ends" with the flanges sit on the front and back of the block?
That's correct.
Just lay a bead of RTV, lay the pan down, lay down enough RTV to fill the gap to the intake and install intake.
....... I was wondering if anyone was using the Fel-Pro 1200 intake gasket (w/o valley pan) and ran into PCV issues? (ie. sucking oil as the PCV sites right above where the oil drains back from the valve cover area) ........
Greg,
Yes, I had the same issue.
You can cut the old gasket, and use the bottom "tray" end if you'd like.
