timothydog
- Mar 29, 2002
I recently replaced my PCV valve (albeit a cheap-o brand from auto-zone) and I am constantly getting oil sucked up through the PCV tube and into the throttle body through the vacuum block.
Do you guys recommend getting a check valve or would you say getting a better brand (i.e. AC Delco) would help.. or is there another problem totally? I have a passenger side valve cover breather but I still have the stock oil fill cap on the driver's side. Will replacing this help?
Tim
Tim
