Parts FS
Hawaiian Turbo
POWER'D BY BUD LIGHT
3.73 gears for 8.5
Stock fuel rail
Stock valve covers
LCA relocator kit
Rotating assy, Crank, pistons and rods
stock IC
Access. bracket with idler
turbo bracket
trunk
hood with 3 small dings
stock heads
underdrive crank pulley
2 flex plates
vac hard lines
front and rear bumper shells(chrome)
oil dipstick tube
oil fill tube
coilpack/module
stock turbo with acc.(adjustable rod)
pass rear taillight assem.
Comp eng. NIB sump kit #CEE 4040
15 X 8.5 Convo Pros drilled for slicks
15 X 8.5 Pro stocks
15 X 3.5 Polished Centerlines with front runners
Hey Paul,
Put me down for the Coil Pack/Module, I was just about to call you, to see if you still have it
Mahalo
Oooooooooops, sorry didn't even read the post in front of me ;) :p well, if Andy doesn't take, I will - let me know :) Thanks Paul
Interested in the fuel rail, vacuum lines, accessory bracket/idler and turbo bracket. And the coilpack/module if nobody else takes it.
I still have Andy's module, and two more coil/modules.
Tommy,parts are yours, just make an offer.
Thanks, Paul
Thanks, Paul
Case of BUD should handle it right Paul? ehehhehe I think that is your flavor
Those Tesoro guys are Budlight drinkers. Budlight, bucket ice to be exact. :D
Sorry, but I'd rather keep it as a unit.
Thanks, Paul
Paul, I may need a CP/Module unit for my parts car... let you know after I check it out further.
