Parts For Sale......Can bring to BPG
Buicksx2
RCA: Home of the The Jack
MAF TRANSLATOR PRO WITH CASPERS ECM ADAPTOR – PLUG AND PLAY $425
RAZOR ALKY KIT WITH CHROME DUAL NOZZLE UP PIPE $400
INNOVATIVE WIDE BAND 02 $130
PLX M300 A/F RATIO SENSOR AND DISPLAY BOX $200
PLX EGT SENSOR $85
3 ACCUMULATOR BRAKE SWITCHES $85 each
5 ACCUMULATOR BALLS $75 each
1 USED GRAY SHIFTER HANDLE $20
2 USED HOOKER MUFFLERS $30
BRAND NEW DOOR GLASS $200 PAIR
3 CAM SENSORS $90 each
2 BILLET VALVE COVER BREATHERS $20 each
2 STEP DOWN IC HOSES $20 each
1 SET HEATER HOSES AND S HOSE $30
1 GM SPARE TIRE METAL DONUT STILL IN GM WRAPPER $15
1 2" VDO EGT GAUGE THERMOCOUPLER DON’T WORK $25
2" GAUGE CUP HOLDER $20
1 PROMPAQ HOLDER UP TO 4 CHIPS $100
1 QUAD AIR VOLT BOOSTER $25
2 SETS CRANE 8MM WIRES GENERIC BLACK $25 per set
1 SET USED BLACK WIRES $20
1 SET 009 INJECTORS $150
1 SET MT ET DRAGS 29.5/10.5/15'S STILL MEAT ON THEM $75
2 STOCK INTAKES$150 each
2 FRONT TIMING COVERS WITHOUT OIL FILTER ASSEMBLY $125 each
1 FRONT TIMING COVER WITH OIL FILTER ASSEMBLY $150
3 FUEL INJECTION RAILS one with larger fitting to accept -12 fuel line $50 FOR STOCK $65 FOR FITTING RAIL
3 POWER STEERING PULLEYS $75 each
1 CASPERS VDO CONVERTOR TACH MODULE – NEVER USED $25
SIDE MIRRORS-REMOTE FOR DS -NO REMOTE FOR PS. ONE BLACK ONE GRAY, BOTH NEED PAINT $50 FOR BOTH
1 TPS TECH MODULE $65
2 DAMPERS COMPLETE $75 each
1 BIGGER THAN STOCK DOGHOUSE $75
2 WATER PUMPS $20 each
1 DELTAGATE USED $25
3 OIL RETURN TO BLOCK LINES $35 each
2 OIL PANS ONE 20 BOLT ONE 14 BOLT $45 each
1 FAN ASSEMBLY $65
2 BELT TENSIONERS $65 EACH
1 USED WALBRO FUEL PUMP $50
2 THREE BAR MAP SENSORS $65 EACH
1 TURBO CRANK USED NEEDS TO BE CUT $175
1 STOCK CROSSOVER WITH DELTAGATE ATTACHED USED $50
1 USED TURBONETICS DELTAGATE NEEDS REBUILDING $25
2 USED STARTERS $20
1 USED MINI STARTER $75
1 USED STERRING WHEEL NEEDS RECOVERING $50
1 USED GAS TANK $75
1 LIQUID FILLED FUEL PRESSURE GAUGE-CONNECTS TO FUEL RAIL $30
1 AUTOMETER 2303 TACH $75
1 BRAND NEW DELCO POWER ANTENNA (INTERNALS only) $85
2 TURBO UP PIPES $25 EACH
1 POWER STEERING DELETE PULLEY $40
1 SET OIL FILTER TO RADIATOR/TRANS COOLING LINES $75
1 FUEL INJECTOR AFTERMARKET HARNESS $75
1 TORQUE CONV COVER $25
4 INTERCOOLER SCREENS $10 EACH
1 V8 FUEL PUMP HANGAR $25
1 V6 FUEL PUMP HANGAR $50
2 STOCK FUEL PRESSURE REG $15 each
1 SET STOCK FUEL LINES $75
1 SET USED DIRECTIONAL MARKERS $25
1 CASPERS INJECTOR WIRE HARNESS $70
1 USED BOSCH EXTERNAL FUEL PUMP $20
1 USED POWER ANTENNA $25
2 USED SUNVISORS LIGHTED NEEDS TO BE REDONE $20 each
ABOUT 5 GALLONS OF MOBIL 424 FLUID
VARIOUS INTERIOR TRIM PIECES ASK FOR BY PIECE $10 each
BLUE GLOVE BOX $25
FOUR ORIGINAL EAGLE GT TIRES 215/65/15 Very Used $100 Set
GN SPOILER CAPS $125
USED CARPET & GN FLOOR MATS $75
1 UNDER CONSOLE GUAGE HOLDERS WITH VDO WATER TEMP AND OIL PRESSURE GAUGE $100
1 VDO BOOST GAUGE $40
1 CASPERS BLACK KNOCK GAUGE WITH AUDIBLE MODULE $100
1 V-PLUS VOLT BOOSTER $60
1 2” AUTOMETER ELECTRIC TRANS TEMP GAUGE $40
2 PERMA-COOL 12” ELECTRIC FANS NEVER USED $45 EACH
1 ATR AIR FILTER RAM AIR CANISTER $35
JEGS LINE LOCK/ROLL CONTROL #63002 $75
I CAN BRING THESE PARTS TO BPG TO HELP SAVE SHIPPING COSTS. IF INTERESTED LET ME KNOW AND WE CAN MEET AT TRACK.
PRICES DO NOT INCLUDE SHIPPING TO LOWER 48, PARTS ARE SOLD AS IS WITH NO WARRANTY EITHER EXPRESSED OR IMPLIED.
PM ME FOR MORE INFO OR PICTURES.
IF INTERESTED PARTS SOLD WILL BE IN A FIRST COME FIRST SERVED BASIS VIA EMAIL OR PM REPLY TO KEEP IT FAIR. I CAN BE REACHED AT BUICKSX2@AOL.COM
THANK YOU
Are any of those deltagates the ones that bolt up to the ATR external gate dowpipes (right next to the turbo) or are they all the style that comes off the downpipe?
If you have one that fits my atr pipe I'd pick it up as a spare. If you have any different springs for them i'd be interested in those as well.
Rich bring the 20 bolt oilpan to BPG. I'll be in the Kanadian pavilion next door. You need money now? Oilpan has baffle?
