J jake616 New Member Joined Apr 30, 2003 Apr 15, 2006 #1 Can somebody please post the part # to the driver side and passenger portholes for the 2003 Buick Park Avenue Ultra? They used to be called ventiports on the older 50's model Buicks.... can't find this # online anywere. Thanks! -jake
T turbofish38 Le Pétomane Joined Dec 3, 2002 Apr 17, 2006 #2 Try GM part number 25740950. These are per port hole so depending on what you are doing you will need 6 or 8 of them.
J jake616 New Member Joined Apr 30, 2003 Apr 21, 2006 #3 Are both passenger and driver side the same but reveresed when installed? Thanks! -jake I will check into that part #.
T turbofish38 Le Pétomane Joined Dec 3, 2002 Apr 24, 2006 #4 No they are the same for both sides. One part number per hole.
K kshef Active Member Joined Sep 6, 2003 Apr 24, 2006 #5 with those you'll have to make holes in the fenders someone sold some stick on portholes a few years back.....i think a place called jay's gn
J jake616 New Member Joined Apr 30, 2003 Dec 4, 2006 #6 What about the newer lacrosse or lucerne 1 piece port holes that share the chrome trime around each "port"? anybody got that part #?
T turbofish38 Le Pétomane Joined Dec 3, 2002 Dec 5, 2006 #7 Lucerne Ventiports Here you go. 3-Holers LH-10397807 RH-10397808 4-Holers LH-21997255 RH-21997256
