85begalttype
just a v6
- Oct 22, 2008
hey guys, in the process of putting my car back together after a frame off. The shell was media blasted and then coated with epoxy primer. I have to do some body filler before base coat. This is a tight budget build for my daily driver 86 cutlass with a turbo buick motor, I want to use omni products since its easy to get locally where i live (canada)
Should the process be:
epoxy primer
filler
then coat over the filler with more epoxy?
then sealer? or not necessary since there is already epoxy
or should i use polyester primer because its easier to sand
then guide coat
then sealer before base coat?
and for base coat i wanted to use the omni paint - acrylic enamel white with the gloss enhancer
epoxy primer
filler
then guide coat
