Blown&Injected
- May 31, 2001
Getting very close to doing the body work, and paint and looking for some ideas on tools and materials.
This is the supply place near me Mattos Profinishes > Home and there is a good chance that they will have a "system" that will determine what happens - but I do not want to get stuck with a bad option.
Due to paint checking, I took it down to the metal and I have been told self etching primer-sealer in one is the way to go. Then base coat and clear coat - it will be black.
I have used cup guns to paint steel but I have never painted an entire car - it looks like many use a different gun for the different stages, but a middle of the road gun may be used to do it all. I am not setting up a paint operation and I hate the fuss of selling stuff so I would prefer to not have to buy a bunch of guns. I understand that the base coat goes down easy, like primer, and I probably will not do enough painting to notice the difference in the guns anyway, so it sounds like the one gun should lean towards the clear coat type of gun???am I right???
Plan to go over all the bare metal with 80 grit - wipe down with some type of cleaner, and spray the SE primer/sealer. Then block with a contrasting fog from some rattle can and go over all the primer with 180 to 220.
What to use to do the cleaning on the bare metal and before shooting the black base and the clear?
Also, the RA sander is an air hog and I have water coming out the sander after an hour of sanding - what to do to keep the air clean? I was thinking that filling the compressor (60 gallon) the night before will let the air cool down but it is clear that the filter/separator I am using is not effective. I am told another filter at the gun and not letting the air line lay on the ground will help.
Any ideas are appreciated.
