P/S pump info...
Chuck Leeper
Toxic old bastard
Staff member
For those using an LS engine w/ hydraboost brake p/s pump: 2 ret port pump]
There is a chance the pump will be noisy due to cavitation, if the return from the p/s gear is hooked to the top port.
I have found other instances that this is the cause, as well as have this problem on the 6.0 in my 55...I found it too late, as I had already changed the pump.:mad:
Others have succeeded in just moving the line...
