I recently replaced my TA60 with a new GT6152. I had to change one of the wastegate solenoid hoses because of the different location of the compressor pressure outlet. I hooked up the "Y" fitting correctly with the restriction towards the compressor outlet. i'm still getting 25+ psi of boost (i didn't stay on it to see how high it would go). It spools somewhat slow (slower than the TA60) but that is most likely due to the fact that my actuator rod is set as loose as possible. please help, i'm getting over 25 psi at not even WOT.
