1- Stock 87gn ecu part #148 to verify (includes stock chip) $120
2- Turbo weak chip 5.6 (80#inj. alky . 23-21deg. 20-30psi . ) $40
3- Stock pass.side header. Great shape not beat. (No visble cracks or leaks , came off of a running car) $90
4- 87 esc module HKP code. Dont think these are being made anymore $75
5- Belt tensioner bought new from napa .Realized the top ear has been repaired . Bought it that way . Never had any issues with it functions 100% . $45
6- 87 gn maf , A1 cardone . Off of a running car no issues it is calibrated correctly (4-6gms. idle 255 wot.) $45
7- Wiring harness #1 is from an 87gn has a couple of melted connectors 3 max. , splices here and there . Would make a perfect donor harness $50
8- Wiring harness #2 not sure if this is from an 86 or 87 gn . Looks good never ran it so I cant guarantee its perfect. 65$
9- Oem vac. block with bolts , 2 bar oem map , egr solenoid good w/ new filter . $35 for all ( will split )
10- 3-bolt exhaust housing for a 68mm turbine (gtq , q trim , f1-68 ) Wg hole has been ported . New dog ears and bolts .$45
11- 87 ttype grille originally chrome , was painted black . Great to repaint black and go . Tabs on top are all intact . Plastic piece on bottom isnt broken either. 65$
12- 87gn fender liner pass side. great shape not broken or cracked anywhere . $120 . ( pm about shipping)
13- 87gn driveshaft 95k miles no vibrations . New greasless hd ujoints on both ends. $90
14- 87gn axle good bearing surface no grooves out of a 40k mile car . $45
15- 2 1/4in. billet wheel spacers. for 5x4.5 or 5x4.75 patterns $30
16- 1/2in. tall 02 sensor bungs have 3 . $ 8 ea.
All parts are o.b.o plus the ride.I accept postal m.o's only , please . I usually ship out same day with a fedex tracker. Some of the smaller items I can send usps flat rate . Located in CT , shipping for the d-shaft , and fenderliner may be a bit tough . Local pickup for those items .
