C chris mccord Member Joined Nov 25, 2007 Oct 25, 2008 #1 I have an old Art Carr OH kit in my pole barn. Is there a shelf life for the kit? Should I pitch it or use it? It's many years old.
D DailyDrifter The Slow and the Curious Joined Dec 5, 2007 Oct 25, 2008 #2 I wouldnt think so just let the clutches sit in ATF to soak before you put them in
C chris mccord Member Joined Nov 25, 2007 Oct 26, 2008 #3 I hoped that it would still work. I didn't want to waste it. Thanks
turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Oct 26, 2008 #4 I would check the rubber seals/soft stuff for rotting. Im sure the barns temps get up there in the heat. If they are OK then rock it
