I have fresh weber stroker motor with girdle, how many quarts should I put in at oil changes, I've heard from 5-6qts. At 5 qts, the dipstick is on add and on 6 qts its on full, just want to make sure the right amount.thanks
My old car was taking 6 qts with the 52, but this car still takes 5 with the 52... both had stock pans as far as I could tell But it it takes 6 to get to the top of the fill line, go with 6.
Once your 52s start coming with plastic cages inside, switch to a Napa or Wix equivalent filter
