I just installed new turbo with remote oiling system from precision. Now after a good warm up oil pressure is close to 10. I also have high volume oil pump. Will changing the spring fix this?
Changing the spring won't change the oil pressure at idle. It will only change your maximum pressure. What was the oil pressure before the turbo change?
