Running a booster plate won't increase oil pressure either. However, if installed with new gears, will give quicker pressure at startup. Ten at hot idle is not bad. I'd leave well enough alone. You may consider changing out the main and rod bearings if you really must.Originally posted by Red Regal T
I run a hi-volume pump. You could install that or install what's called a booster plate with your stock pump. Changing your timing chain won't increase oil pressure. If you have the original in your car, by all means, replace it.
