I was driving to work the other day and heard a tapping coming from the engine, like a bad lifter. I glanced at the oil pressure gauge and it read approximately 30 psi. Not normal at highway speeds for my car but I was two miles from work and figured I could baby it the rest of the way. As I got closer to work, the oil pressure slowly dropped until the gauge registered 10psi at 2000 RPMs. I was about to shut it down when the oil idiot light popped on. Luckily I was able to drift most of the way to work. I started it back up and had about 15 psi, enough to get to work. Still sounds like one of the lifters is suffering a collapse, I'm hoping from little oil pressure. Where do I start? I was thinking about checking the spring at the oil pressure relief valve and seeing if it broke or maybe a particle of dirt in the valve not allowing it to close. Could I be that lucky or does this sound like a worse problem. It seems strange the oil pressure SLOWLY dropped over a two minute period. Any ideas?? Please help! I've never taken out the oil pressure relief valve. I would appreciate any advice on that job. Thanks.
