oil out the turbo
jclaflin
hope some one can help us out.working on my sons 83 had to have turbo rebuilt the old one was toast put it back together still throwing oil out the exshaust. changed pvc valve at the same time. what else could be causing this problem?
Raw oil or smoke? Take the up pipe to the turbo and see if there's oil in it. You may have some coming out of the exhaust ports from worn guides.
Sounds like they didn't get the seal right. How long ago did they repair it and who was it?
just had it done have about 3 mins on it started pouring oil out G-pops did it. sent it back he said every thing checked out good not making sense. been doing a little research everything is pointing to a bad turbo seal
I'll send you a PM on who I use. Reed know his stuff when it come to the carb turbo system. He used to race them.
