BlackMetal
- Sep 29, 2005
I drilled out the two bolt holes in the stock oil drain flange to bolt it up to an upgraded turbo that requires the larger bolts at the drain flange. If I went back to something like a 49 which is the stock center section I believe, will going back to the smaller bolts leave too much slack with the flange holes enlarged like that? Any sort of bushing or anything to take up the slack? Or do I have to buy a new one.
