No. I just got around to installing the guages. The coolant temp sender in the side of the block was fairly easy (except for the loos of a lot of fluid) but the oil pressure sender is a different story. There were two senders attached in the spot where the oil line goes to the turbo (via a brass distribution block). It appears that the factory oil pressure switch is attached there since it is a three wire plug/switch. When removing all of that, I broke the brass distribution block so I had to find another. While I was at it, I bought a new oil pressure switch and installed it along with the new brass block and Autometer sending unit. Since I ended up draining the radiator, I noticed that it isn't in the best shape internally. I am waiting until I have time to remove it for some R&R before I continue with the install of the guages (oil pressure and water temp).
