T turbogimp Member Joined Dec 3, 2003 Apr 23, 2005 #1 Is there a o2 sensor that handles leaded fuel better than a stock type? Thanks in advance.
8 86brick It's just a V6 Brick..... Joined Sep 20, 2001 Apr 23, 2005 #2 Yes the Denso... Part # is 234-1001 and they can be had from www.sparkplugs.com
T TurboBuckeye Wolf In Sheep's Clothing Joined May 1, 2004 Apr 24, 2005 #3 Originally posted by 86brick Yes the Denso... Part # is 234-1001 and they can be had from www.sparkplugs.com Click to expand... There ya go
T turbogimp Member Joined Dec 3, 2003 Apr 24, 2005 #4 Thanks. so in anybodys experance say if you run leaded fuel all of the time how long do you think it will last? thanks again
R Randy Greenoe Member Joined May 24, 2001 Apr 24, 2005 #5 I have run about 30 gallons of leaded 110 thru mine and it still seems to be fine. The last AC Delco lasted 3 passes and crapped out.
T turbogimp Member Joined Dec 3, 2003 Apr 25, 2005 #6 Thanks for all of the info. Just wanted to find out before the race fuel distroys my O2 sensor. Thanks again
C crownvic96 Member Joined Jan 31, 2005 Apr 26, 2005 #7 caspers electronics sells a heated 02 sensor kit thats pretty nice. it will get you into closed loop faster and is less prone to fouling by leaded gas.
