I just bought 84 gn. It runs good, but I question if it is pulling enough boost. It is pulling between 7 to 9 lbs. What should it pull. CAr has 126,000 miles.
Did you find out your boost problem? I just bought a 84 hotair car and put a new mototr in it and Im only pulling about 2 pounds of boost and cant figure it out. Hope you figured it out and can help me. Thank you.
I plan to keep it stock, nice street rod with some zip. How do you tell if the turbo needs rebuilt? Is it better to rebuild turbo or replace with new or reman? What is the pro and con of going to a performance turbo? I am new to the ha/turbo world. I really appreciate the feed back. I think this site is awsome.With everything being perfect on your car, the only thing that would keep it from making boost would be the wastegate remaining open.
If the wastegate is working properly then you have a really good size exhaust leak before the turbo (you'd hear it for sure) or you can't produced enough pressure in the intake manifold (intake leak) or the turbo needs to be rebuilt.
Those seem to be the clear causes for such low boost.
Another cause of low boost is a plugged up CAT.
