NOS and used parts for sale
Interested in the (2) new lower body bushings and hardware. Are these the one's that go on the frame. If so could you list the part numbers.
Yes these 2 are the one's that go on the frame at position 3 which is in the center of the door frame. I purchased these from Kirban Performance part number KPP 7306. They are aftermarket and fit an 86 and 87 GN. The 2 bushings come with hardware eg bolts and washers and installation instructions. They are new and never installed. The kit from Kirban included four bushings for position 3 and 4. I only needed to replace position 4 on my car.
35. NOS A/C High blower switch. $25
Is this the metal relay that hangs on the evaporator housing by the accumulator? Mine has yellow print on it - 10018449 CA 7299A Made in Canada and some tiny unreadable letters.
Here are pics of the one I have with the AC Delco box. It is stamped "Made in China". Part number 10018449. No yellow print. Black print.
I recently sold my '87 GN and now want to sell all the back up parts that I have accumulated over the years. Most are NOS and are either in the original box or wrapper. Prices are OBO plus shipping and plus 3% pay pal fee. Buyer pays shipping from NC and I will only ship to the lower 48 United States.
1. NOS coil pack -tested. $60 SOLD
2. NOS ignition module-tested. $175
3. NOS cam sensor. $175
4. (3) refurbished wheel center caps. $75
5. (1) used wheel center cap. $20
6. (24) various NOS Plastic connectors. $75
7. Used clear back up lense. $10
8. NOS Mass Air Flow sensor. $300. SOLD
9. NOS power steering reservoir (upgraded model). $190
10. NEW never used Scanmaster 2.1. $250
11. Used underbody heat shield for catalytic converter. $75
12. NEW fan belt. $15 SOLD
13. NOS "s" hose. $35
14. (2) NOS 3.8 SFI TURBO hood emblems. $90. SOLD
15. (4) NOS Grey pull strap covers. $65
16. NEW 4th gear pressure switch. $10.
17. Used intercooler shroud off 52k mile car. $ 120.
18. Used GM Parts and Illustration Catalog. $95.
19. New Factory service manual CD. $20.
20. Rebuilt stock turbo with dynamic seals ( rebuilt by BISON). $550.
21. NOS GM numbered spark plug wires. $125.
22. Reproduction (new) turn signal stalk with cruise and wiper control. $45.
23. NOS Idle Air Control Solenoid .$50
24. NOS O2 Sensor. $30.
25. NOS throttle position sensor. $75.
26. Used sun visors with lighted mirror. $50.
27. NOS crank sensor and bracket, $85
28. NOS A/C compressor cut-off switch. $40.
29. NOS A/C compressor relay. $20.
30. NOS A/C high pressure switch. $60.
31. NOS A/C Pressure cycling switch. $35.
32. NOS fuel pump relay. $25.
33. NOS cooling fan high temp override switch. $50.
34. (2) NOS hi/low cooling fan relays. $85.
35. NOS A/C High blower switch. $25.
36. Used (not working good and good candidate for rebuild) heater core. $25.
37. (3) NEW FELPRO fuel pressure regulator "o" rings. $10.
38. REMANUFACTURED ECM. $135.
39. (2) NEW lower body bushings and hardware.$10.
40. Used grey Buick owners manual cover. $10.
41. Used black Buick owners manual cover. $10.
42. Used Grey shift handle complete. $$60.
43. NOS fuel pressure regulator. $100.
44. NOS ESC spark control module. $175.
45. NOS boost control solenoid. $150. SOLD
46. NOS fan delay relay. $85.
47. NOS EGR valve. $70. SOLD
48. NOS knock sensor. $50.
49. NOS radiator fan motor. $300.
50. NOS GM door seals, LH & RH. $375.
