Cranks a couple a seconds then clicks. Hooked up the battery tender and charged battery. Voltage 12.5 at the battery. Scan master showed 11.4 or 11.6 with the key in ignition/run (and decreased by 0.2 for each start attempt). Checked the battery drain - don't think I have too much, in the neighborhood of 20mA nominal. Volts light does come on when the key is initially turned to run. Car is in the garage - so I haven't rolled it out to maneuver my truck to jump start it yet (so I could check the voltage at idle).
In the last few months or so, the car needed a shot from the battery tender after a week or two (it's a garage queen). Now, that didn't even do the trick. Last time I skipped the battery tender and just jumped it - and it ran fine.
Can't find my records on the battery (AC Delco)...not sure when I got it...but it takes a charge and does put out some decent voltage.
Thoughts? Recommendations? I'm not a smart man....
Thanks all!
Matt
Thanks all!
Matt
