i installed a FAST on car so i am hard wiring the tcc solenoid. i have power going to A the tcc solenoid(just pulled pan off to verify) if i ground D the solenoid clicks but seems weak but i have never checked another one, while driving on the interstate i would ground the tan/black D wire and wouldn't lock up also never got any kind of a signal from pin B (4th gear switch) i have been reading and the 4th gear switch is a one wire and most say it needs a two wire switch??? regardless if i directly ground the neg side of the solenoid it doesn't lock. the speedo isn't working but at this point that cannot effect the tcc since i am hard wiring it.
while i got the pan off is there any other troubleshooting you can suggest
thanks
thanks
