do you smell gas around the car (a leaking return fuel line) ?
try clamping the return line to block flow and if pressure stays longer then the fuel pressure regulator is leaking internally , if still dops then possibly injectors (you would get big puff of smoke on startup, do you ?) otherwise the fuel pumps internal check vave is leaking or if an aftermarket pump is in tank the short hose in the tank could be leaking
easiest is to swap in a fuel pressure regulator and eliminate it as a source
