Cruzbear
- Feb 10, 2006
I have a Turbo 400 with brake. Reverse manual. 3 speed
Doing some spring maintenance, pulled the pan off cleaned it replaced the filter, new gasket, fluid etc.
Started the vehicle for one minute shut it down, started it up agian a few minutes later put it in gear and rolled it off the lift, then shut it down on my drive way and cleaned her up a little.
I then started her up put her in gear tried to drive down the street but could only muster a rolling speed and have no reverse.
What could I have done wrong in the dropping the pan? The cable seems fine I can shift and it does move, something inside I may have upset?
Thinking about my steps and possible causes... I did not fill/prime the filter... I did not let it run for long, I have heard that this could make a difference in getting everything circulating properly..?
any help would be great,
jim
jim
