turbojustin
Ninja
- Jan 8, 2003
I just picked up a hybrid LC2 Blazer that is running a stock ECM. It runs rough when under boost and sometimes does not start. It just cranks over like its getting no spark. Fuel pressure seems good at startup and idle.
I opened the ECM and it had no Calpack in the socket. I replaced the missing calpack which turned off the check engine light, but it still suffers under boost and has the no start issue.
Also, the radiator fan never turns on. I tested the relays and they are good. The fan will turn on if I jump the relay.
Here's my question...Could this all be signs of a bad ECM? Could the ECM have been damaged from driving the truck with no calpack?
I have already replaced the following sensors with known good parts: MAF, Cam sensor, crank sensor, ignition module, and coil pack. Unfortunately, I don't have a spare ECM.
FYI: The truck has a Caspers modified stock engine harness. Also, the previous owner said the truck has ran this way ever since the engine swap.
