no brake lights
kh440
Jo Bu needs a refill!
Discovered I have no brake lights, except for the high mount. Threw another switch at it but did not fix the problem. Fuse is ok (found a 25A A/C fuse melted but not related). Have turn, tail and hazrd lights but no brake. (Car does have the LED tail lights if that matters). Wrong switch or another issue?
pull the hush panel and the small trim panel (has the small vent in it) under the column....youll see a long connector attached to the column with the turn signal and horn wires in it....look close at the white wire and its related terminals...ive found issues with the connection here......
clean, tighten if possible,bypass the plug all together is another option...HTH.
