When using Turbolink it never shows me that I'm in 4th gear even when I really am. I did a tranny service, changed the 3-4 pressure switch, and still no 4th gear on t-link. What would do this, and how do I fix it? Thanks for the help.
someone may have the 4 th accumulator circuit in the case or spacer plate not allowing readable signal at the pressure switch .check this by verifying oil is at the 4th tap in 4th w/a gage . if it is or trans is original ohm out the wiring from the switch to the computer and you may find a broken or loose connection .if not suspect a faulty ecmwww.ckperformance.com
