Hello guys,
I recieved my new TT chip the other day but have not installed it yet. After reading the instruction, it came to my attention that:
1) I better get my header leak fix first.
2) I may have to hire someone to do it for me since I don't own a scan tool or scanner 2.1, and besides, I don't know how to use those tools anyway!
3) Do I really need to mess with those adjustable parameters that are built in the chip?
The TT chip was burned with my T+ in mind. So, I just need to make sure that all the parameters (1,2,3, and 4) are all at 128...right?
I mean, do you guys go to a dyno or track and adjust Up and Down from the 128 base on the Fuel and Spark tables? Is it necessary?
OR, do you just plug in, make sure that all is cool with the IAC, TPS (idle and Wot) and O2 Volt readings and 128, then play with your fuel pressure regulator to tune it?
I already replaced all the old stuff like (plugs, plug wires, fuel filter, motor oil and filter, O2 sensor and PCV) I just want to see her run better with some PEP! I know that my new and now audible in the cabin header leak is eating some power, it will be fixed soon after the holidays.
Thanks advance for your inputs:biggrin:
