BlackoutDrunk
Spring Loaded Idiot
- Jul 30, 2007
I just put in 60# injectors and a TT SD chip. My car seems to be running kind of rich across the board. I turned on the wideband correction for WOT and it holds real nice to my target but I would like to lean it out when cruising. Do you guys think that would be settings in the chip or should I look at fuel pressure adjustments? Or maybe a combination of both. I started with the base setting of 43# line off for fuel pressure. I attached a powerlogger file before the wideband correction was enabled so the brief WOT is not a representation of current but the cruise is basically the same.
