The dealer replaced it in a '98 Park Ave. Now there's an air type of leak. It's hard to hear at idle. You don't even have to mat it. If you just get into it a little, it has a gurlgling type of sound. You can hear it easily at any rpm from 2200 up, when you get into the throttle. It feels a little down on power.
The car now idles at least 100-150 rpm higher.
Is there a gasket between the SC and the intake? Does it seem like the guy left it out, damaged the gasket, didn't use some sort of sealer on it, not torque it properly?
Is there anything else in the assembly that would cause this new problem, since they worked on it?
What can I tell them to look for?
