OneQuikSix
- Jun 7, 2001
For those of you still running a stock fuel tank, how did you run a new/larger return line from the fuel pressure regulator? I've already run a new -8AN braided stainless feed line from the fuel filter to the rail. Now I'm trying to figure the best way to run a -6AN return line back to the tank. The main reason for the switch is the factory return line blocks the coolant temperature sending unit connection on the front of the intake manifold when using a Champion Racing aftermarket intake with billet fuel rails. I guess my main question is how to physically plumb the -6AN line into the tank or otherwise splice it into an existing line (either factory return line or possibly vapor line?). Any ideas would be greatly appreciated. Thanks.
