Just got motor back together, short block was untouched except for roller 206 cam, gn1 heads, new converter, fmic. Car also had cpt62 ball bearing turbo, alcohol, 3.5 inch dp and external wastegate. Anyways, car had terrible miss, as if running on 3 cylinders. Found out I had bad ground, which fixed problem 50pct of the way.
Set TPS, and the other numbers on scanmaster seem right. Car stumbles badly and won't build boost for say...3 seconds. Then it slowly builds through the stumble, and at 7 psi of boost it hits a sweet spot and runs great. I only went up to 13 psi or so half throttling it. Any ideas, throwing a 100 person cruise Friday, so need this thing to run decent.
