Well, sad story, my 1500 mile Groom's stage 3 motor is junk. The last two times out I noticed the warm oil pressure was down from its usual 50psi level to about 30 when cruising. Oil pressure was fine at cold start-up. Never made any noise as far as I could hear. I decided to drop the oil and disect the filter. Needless to say, filter was full of metal. So I imagine a bearing went bad somewhere. The car only saw 4 passes down the track, all below 20psi with very minimal knock on scanmaster. Hopefully Grooms will stand behind their motor, especially since when I recieved the motor, I unwrapped it to find a broken ARP rod bolt falling out at my feet. I then had to call them and have them send me another bolt to replace it after I pulled the broken half out of the threaded portion of the rod. I guess I should have seen this coming or at least sent the whole motor back at that point. Oh well, either way my year is over. Time to dig out the cherry-picker.
