Hey guys...I need help deciding if I should buy a T-Type. It's an 83 Regal.
Went to look at it yesterday, and it's extremely clean. It starts right up, and it drives, but that's where the good ends.
Here's what I can tell about the car. The owner had no idea what was going on, as he got the car because someone owed him money.
It starts right up, but he said when he drives it, it doesn't make boost. "Doesn't feel like a turbo should".
1) There's what appears to be a standard Q-Jet on it. Maybe it is making boost, but running way too lean with that carb??
2) There's a few vac lines here and there not running to anything. Obvious problem. Also...the oil fill cap was not vented. The owner said they couldn't get it to start for a long time. They finally pulled the fill cap, notched it so it would breathe, and it started. I'm guessing they pressurize the living $#!^ out of the crankcase.
3) There's an ECU of sorts laying in the back seat. If I recall correctly, it said boost or turbo or something like that on it.
4) The MAACO paint job is falling apart. Least of my worries....along with some other minor body issues. Nothing the junkyard can't fix. Also, the front springs were cut to drop it. Now it rubs. Also...easy fix.
Here's the good. I have access to a 1985 SFI motor. For the price of free. The thing is, though, I would need to get this 83 engine running first. The free engine is about 1400 miles away. I'd want to get this one running first.
The guy's asking price is $4000. Which I think is absurd. I'll definitely offer him less than that.
Knowing the carb and boost issues...is this something that might end up being not too bad of a project? I know I still need to check the turbo for shaft play, but sourced a rebuilt one nearby.
Thoughts??
Thanks guys!
Stu
Thoughts??
Thanks guys!
Stu
