Hello folks,
I am a first time GN owner and I need some help.
Ideally, what amount of timing do you guys typically run on pump gas with 16 to 18 psi in low gears and high gear? And the same goes for fuel psi. FYI, I have the T+ and extender chip which gives control of timing base/wot and fuel base/wot.
It just seems that I have to make adjustments every time I go out for a cruise to find that sweet spot. Rather risking any engine failure, I fugure I better ask you guys for help on this matter. Some sort of "true and tried" set up or base line that I can build on.
Thanks in advance for all your help
Thanks for your help. I am posting the same question on the forum to see how others feel cope with this.
