scot w.
GNSperformance.com
- Feb 19, 2005
DSE just released their complete line of G-Body Coil Over shocks. These are direct bolt in shocks with a neat feature for the rear. The rear kit features a mounting bracket with two holes, one for your regular ride height and the top hole is for when you go to the track and change out your tire all you have to do is unbolt the lower shock and move it up to the upper hole and your ready for your larger tire to fit...No more adjusting the nut with a spanner wrench and marring up the threads or the nut..
These are In Stock and ready for shipment!!
For pricing and info click here------> GNS
The DSE G-Body Coilover Conversion Kit allows the latest in coilover spring/shock technology to be bolted on to any G-Body, bringing your classic’s handling and ride into the 21st century with our ‘Detroit Tuned’ valving. The base coilover package offers extensive ride height adjustability and DSE valving. Our optional double adjustable coilovers offer adjustability with multiple settings for both compression and rebound. The ultimate package is our monotube remote reservoir coilover set which offers separate fluid canisters for optimum adjustability.
Base Shock(No compression or rebound adjustments)
Lightweight aluminum body coilover shock allows ride height adjustment. Specific "Detroit Tuned" valving provides superior handling performance and ride quality under all conditions. 100% dyno tested.
Double Adjustable Shock
Includes all features of base shock plus installed independent compression and rebound adjustments with the simple turn of a knob. Specific "Detroit Tuned" valving provides superior handling performance and ride quality under all conditions. Low friction components provide responsive, consistent, fade free performance.
Remote Canister Monotube Double Adjustable Shock
Includes all features of double adjustable shocks. Specific "Detroit Tuned" valving provides superior handling performance and ride quality under all conditions. Incorporates a gas charged bladder design to provide both high frequency and low speed dampening control.
