need turbo bracket
TurboGTA
took the turbo off the TTA and discovered that I'm missing the brackets that bolt to the turbo and then to the large horseshoe type bracket under the heat shield, I don't remember if its a 1 piece bracket or 2 seperate brackets that I need
please send pics so we can confirm on the correct bracket
thanks
Is this the one that holds the heat shield on? It's one piece that bolts to the block and the turbo. I have one if you want.
no I need the smaller 1 that bolts to the turbo and then to the top 2 holes of the bracket you posted a pic of
