I have a 1984 T-Type I just bought and we have run into a bit of a problem. The car had a bad ignition module in it so I have upgraded the module with caspers hotwire kit and added new coils. The problem is when you try to start the car, the key wont turn far enough to engage the starter. It will also not turn all the way back. It will turn power on, but that is all. I have bought a new ignition lock cylinder and key along with a nuetral safety switch. We have also tried adjusting the tilt wheel in several positions with no luck. I will be removing the steering column next week was just wondering if anyone had any other ideas while I have it apart putting some new stuff in.
The ignition will also turn the same without the key in it. So I think maybe someone has tried to screw driver it or something possibly in the past. Not sure. I will keep you updated if we get it. I bought a code reader as well so maybe that will tell me something. Also the check engine light does not blink or anything it just comes on with the power but that is all that happens.
