F Fast Farmer Member Joined Jan 24, 2012 Apr 19, 2012 #1 Finally got it back running today. Drives great, idles great, put a little boost on it, like 13-14 psi, runs great. But if you mat it, it will pop and all the power goes out of it. Thanks.
D DaRonne Edwards Member Joined Apr 9, 2012 Apr 20, 2012 #2 Sounds like the ignition module may be getting bad. Check to make sure the little screw on the side where it plugs in is screwed in tightl not loose.
Pronto Believe nothing you hear and half of what you see. Joined Dec 9, 2002 Apr 20, 2012 #3 Here's some tips on what to look for: http://www.vortexbuicks-etc.com/engine_starts_but_does_not_run_p.htm I'd suspect a weak coil.
